In the end it’s what you like that counts.Hope all are well. Would you guys recommend the Case jack swell center or peanut knife for an every day carry and is bone better than synthetic? Sorry will be my first pocket knife.
I’m not the right guy to answer, but maybe that will help others direct him to the best choice.Hello all. My grampa used to carry a frontier peanut which I have but seems beat up and have no clue about restoring. Wanted to get something to honor that and USA made. Is the case peanut the best option? Also is bone (chestnut) a material that will last? Hoping one day my grandkid will like it as much as I like gramps. Thanks in advance. I am new to this so easiest maintenance prob the beat.
Is CV harder to maintain? I’ll oil and clean it but not sure how great I will be at sharpening. How often do you need to sharpen a bladeSmkw has a exclusive case small swell center jack that has carbon steel and burlap micarta one of my favorites.
I like the 25-1/2 swell center more than the peanut, but even more so I recommend the 08 pattern half whittler.Hope all are well. Would you guys recommend the Case jack swell center or peanut knife for an every day carry and is bone better than synthetic? Sorry will be my first pocket knife.
Oiling/cleaning is all you'll need to do for a CV or Carbon Steel blade. Stainless Steel can still rust, but generally requires significantly less oiling/cleaning.Is CV harder to maintain? I’ll oil and clean it but not sure how great I will be at sharpening. How often do you need to sharpen a blade
Thank youOiling/cleaning is all you'll need to do for a CV or Carbon Steel blade. Stainless Steel can still rust, but generally requires significantly less oiling/cleaning.
I don't think you'll notice much difference between sharpening Carbon/CV versus SS, especially if you haven't done a lot of sharpening before. I think it is generally agreed upon that Carbon/CV is a little easier to get sharp, however and fwiw. I think most prefer Carbon/CV for the patina it takes on which adds character and tells a story. That is certainly why I prefer carbon over stainless.
This is great. Thank you for taking the timeI like the Peanut concept, but it's just a bit too small and fumbly for my hands & fingers. The Medium Jack and large Pen are really good for me, the Small Swell Center Jack is in the "not bad" zone.
I do better looking at comparison pics than trying to judge of measurements, so here's a few snaps for anyone in the same mindset.
Most of the Case patterns I have, except I forgot to put the Small Swell Center Jack in this shot. Oops. L -R Tribal Lock, single-blade Trapper, single-blade Stockman, single-blade Copperhead, Mini Copperlock, single-blade Tear Drop, single-blade Barlow, Medium Jack, large Pen, Sway Back Gent, Pocket Hunter, Peanut.
Next two shots show the Small Swell Center Jack, Medium Jack, Pen, and Peanut from the side and from above.
The same 4, in-hand.
And open.
Hope this is helpful to those who use visuals better than dimensions.
Pocket hunter is cool. Did you notice the swell jack to be off centered or with gaps. Saw some reviews complaining about the construction.I like the Peanut concept, but it's just a bit too small and fumbly for my hands & fingers. The Medium Jack and large Pen are really good for me, the Small Swell Center Jack is in the "not bad" zone.
And open.
Not many brick and mortar here in NY unfortunatelyI think it depends on what you want to do with it. If you just carry it to cut a stray string, open packages, peel apples, stuff like that, I don’t think you can go wrong with either. If you’re the outdoor work type and need to do heavier work with the knife you might look at a case copperhead. Not the mini copperhead but the 4 inch (something like that) one. I think of it like a biggie size peanut.
Lots of guys do just fine carrying peanuts and I’m not trying to sway you from it. I tried the peanut myself and just prefer a more substantial sized knife. I like a jumbo stockman. Case 6375, Buck 307, Remington 9501. Like that. All 4 1/4” stockmans. I’ve found with small knives like the peanut that most of them I have a hard time opening because of the short blades and more shallow nail nicks combined with the shorter springs just make it harder for a man (me) with thin, girly fingernails that bend and crack easily.
All this to say, you might want to pick out your knife in a brick and mortar store where you can try several out before you buy.
That’s unfortunate. Down here in Tennessee nearly every small town hardware store and most farmers Co-Op’s have a Case knife display. Might look around and see if there’s any like that up your way?Not many brick and mortar here in NY unfortunately
