It's not what the knife can do to the paper. It's what the paper will do to your knife.Haha ...you should see what I do to the knife..... :0
Reminds me of a Spyderco Chinook. Thanks!Love that blade shape![]()
Looks like a great day.At the range with the daughter today.
I have the same set up and today with a large stockman at 20 degrees the stone was taking jaw metal off. Looks like you set the blade spine in the back of the jaws per directions. Does not appear you have a problem with the stone removing jaw metal. Do you always use 25 degrees or base angle on blade?![]()
Decided to fix a chip on my Beautiful Bear&son that it came with free of charge from the dealer and or factory. Fortunately it’s an absolute beautiful example without that exception. Next up my A.Wright that’s smooth but less then desirable. Couldn’t think of a better time then Christmas night after a few egg nogs and cold beverages![]()
It’s a new setup I normally use my Edge-pro but it depends on the blade and if I’m re-profiling or not. I’ll also use a black sharpie to see were the stone is hitting and then adjust the angle accordingly so it’s from the edge back and then change it if I want a secondary bevel . But for the few knives Ive done with this setup 25 to 26 degrees seems to do the trick .i also found that with 400 grit or lower on this setup the stones want to jump around so using super light pressure and it helps. This is my first dry stone sharpener other then it leaving less of a mess I prefer wet stones .I have the same set up and today with a large stockman at 20 degrees the stone was taking jaw metal off. Looks like you set the blade spine in the back of the jaws per directions. Does not appear you have a problem with the stone removing jaw metal. Do you always use 25 degrees or base angle on blade?
Thanks
That’s all you need brotherThis one - Pretty much daily for a while now.
Thank you for the information.It’s a new setup I normally use my Edge-pro but it depends on the blade and if I’m re-profiling or not. I’ll also use a black sharpie to see were the stone is hitting and then adjust the angle accordingly so it’s from the edge back and then change it if I want a secondary bevel . But for the few knives Ive done with this setup 25 to 26 degrees seems to do the trick .i also found that with 400 grit or lower on this setup the stones want to jump around so using super light pressure and it helps. This is my first dry stone sharpener other then it leaving less of a mess I prefer wet stones .
