how about a pic of that fixed angle jig you use?When I sharpen blades on the belt grinder I do it on the flat Platten with edge downward. I just try to keep the distance between the spine of the knife and the belt - the same . This way the angle stays the same too. With some practice it is easy. But I only use the grinder on very dull low quality knives for sharpening. For my blades I use diy fixed angle jig with diamond plates. Or if the blade is very thin behind the edge - I sharpen it by hand on a stone. Of course many people use belt grinder for sharpening and it's fine, but If I spend 20+ hours to make a knife I can spend 40 more minutes to sharpen it by hand.
Good to see you still kicking around here. I haven’t been around much but hadn’t seen your posts lately.View attachment 2060406Great for setting edge angles as well as false edges.
I just turned over number 79. Slowed up a little but still giving effort. FredGood to see you still kicking around here. I haven’t been around much but hadn’t seen your posts lately.
