I've given some more thought to the reprofile vs sharpen-it-away-over-the-years approaches. I think intended use makes a difference.
I have to admit, one of my most frequent users as a garden tool has a chip on the end where a friend smashed it into a rock. It doesn't affect the utility for my use because the chip is on the tip, so I haven't bothered with the chip other than touching it up with a file to align the edges.
If the khuk is used for splitting a chip won't make a lot of difference. On one used for cutting or chopping it will. Look at the nice cut edge when you sever a branch. The wood fibres are cut, not crushed. However if you have a chip in the blade the fibres will be crushed and torn where the chip is. You won't chop as deeply either.
In Nepal, the khukuris as farm tools are consumed over the years. I suspect how often they are sharpened or reprofiled depends on the use. If you're digging potatoes or splitting wood it doesn't make much sense to continually sharpen and/or reprofile. If you're cutting wood, butchering, etc, then it does.
If the khukuri is used as a weapon then it should be maintained with no chips. A weapon may be called upon to cut bone. Such a tool should be maintained so that any cut it has to perform is a good one. It is too much effort for not enough benefit to maintain a farm tool in the same manner a weapon should be maintained.
I still think that it would take many years for one of us light users to consume a khukuri, not to mention the years required for consuming a HI afficionado's whole collection!
