Well, I've made myself a sharpening system with magnetic table for sharpening kitchen knives and I don't need to hold the knife when sharpening.I've also had the Edge Pro system and yes, using your non dominant hand takes a little bit of getting used to but once you set the knife up, flipping the knife over to sharpen the other side works quite well.
They also use (and include) magnets with they're system. Switching hands kind of removes that being locked in and having to rotate the table. Once you set the distance with the blade from the edge, it works quite well. They're not as expensive as Tsprof or WE, little more expensive than KME but I think it's a little more flexible than the KME (owned the KME also). I think it's a good middle ground, just my opinion also for a "fixed" system.Well, I've made myself a sharpening system with magnetic table for sharpening kitchen knives and I don't need to hold the knife when sharpening.
It's all about combination of magnets force and friction force between the blade and the table.
I don't know about pivot smoothness but switching hands when sharpening on guided system seems cheap and off these days.
Just saying but..... to each their own, I guess.
Gritomatic sells the edge pro stones. I bought other brands of stones from Gritomatic and the stones were very uneven. I've only had two sets of edge pro stones and never had an issue with warp or the stones being uneven like the other brands I've bought from Gritomatic.
No, all of the Boride stones are 1/8". I know EP makes sure the stones are flat before they mount them.The thing with EP specific stones is they start thin (1/8"?) and get thinner as the grit goes up, Gritomatic stones all start at 1/4" I think?
I must have gotten a bad batch then because the stones I received started thicker at the low grit and went thinner as it went up. I literally laid them out in order and you could feel if not see a step from one stone to another. The 1000 stone was 0.129", 600 was 0.124-0.129", 400 was 0.160, 220 was 0.156"-0.163". I can't find the notes I had on the 120 stone but it was even thicker. So my mistake, they ended up at 1/8", not started at, it has been a few years and I got it mixed up.No, all of the Boride stones are 1/8". I know EP makes sure the stones are flat before they mount them.
I think 1/4" thick stones "handle" better in a guided sharpener than thicker ones so there is an advantage to keeping them thinner.
Interesting.I must have gotten a bad batch then because the stones I received started thicker at the low grit and went thinner as it went up.
D Diemaker , You made the bracket.No, all of the Boride stones are 1/8". I know EP makes sure the stones are flat before they mount them.
Psst, notice that nice stainless steel bracket that holds the moving stone clamp? That thing is a work of art.
Designed and made, it was on the sharpener I made 7 years ago. Now 4 of the parts from it have made it to production.
It ticks a few of the boxes but there is a lot of daylight between them. We all have very different opinions on how best to sharpen a knife.I thought this new release looked like your sharpener you made.
