Two things that are 100%key to me on this subject-
#1) Why use blue tape? It Always comes off. Regular masking tape does not. I stopped using blue tape on the blade years ago, and will never go back. You guys can't tell me blue tape doesn't come off- at least sometimes, like when you have a longer session reprofiling. You couldn't make me go back to blue tape. It's worthless in this application. If you have a hard time getting it off use wd40, goof off, lighter fluid, whatever.I deplore re-masking.
#2) I take an old rifle case, not a nickel plated one, just a pure brass one, and set it on a grinder so that I grind the neck and shouter off until I'm left with a sharp edge of the case mouth. With this I cut the excess tape off from the tip of the blade to where the belly starts. I've been doing this for years, have Never scratched a blade, and you are left with a perfectly masked blade.
