oldrifleman
Platinum Member
- Jan 5, 2006
Ok, when using the polishing tapes, do you use them like a sharpening stone and cut into the edge, or like a strop and pull away from the edge? Steven
I will stress the edge between stones (and before the final few light passes) by cutting a roll of printer paper in a slicing manner, delibrately putting lateral force on the edge.
These blades are so soft that I just hit the main bevel with the coarser stone, removing whatever rolled/impacted mat'l that is there. (including the microbevel) - so the resharping process wouldn't be helped by a microbevel.
I seen the edge dented (reflecting light) in about 20 places after press cutting a semi-frozen banana loaf that had crushed nuts in it - LOL - but the grip / shape / lightness / overall length make it user favourite.
I have done many edge retention comparisons freehand in the last few months which have been posted. The initial sharpness isn't lower than obtained by jig sharpening on the sharpmaker, I would never have switched otherwise. As a minimum I accept edges that push cut newsprint at about an inch and I consider that a bit sloppy and optimal is 2-3". If you go back even a year or two then I was just looking for a clean shave with any push cutting ability.
Could you please clarify how you test sharpness by push cutting newspaper?
