I started using a belt sander to sharpen my knives and have been happy with the edges I've gotten so far. I still can't get them to cut hair without touching skin but they will shave and easily slice paper. Now I don't believe my problem is not removing the burr as I am very careful about it. I remove on soft wood, then cork, then surgi-sharp belt with veritas compound. I check my edges and looking straight down at them they reflect no light and slight angles no glints either. Then I use them in the kitchen for veggie slicing. When I'm done and look at the edge under light I can see very slight little glints in random areas along the edge when held at slight angles. Can't see any looking straight down. Usually close to the front third of the edge as I use that area the most. The edges are still very sharp and still shave and easily cut thin paper. Are those tiny glints normal? Is that just the slight wear as it's no longer "fresh off the strop"? I tried batoning for the first time to see what it was about with a Mora #1 after given the same treatment and after a bit of pounding the edge into wood and twisting it was still very sharp when i was done so the edges seem to be holding up but I've only been sharpening like this for the last couple weeks so don't really know the edge holding yet of my sharpening. Also watching cooking shows I realize my knives still aren't super sharp yet as i can't quickly push cut my knives through material like they can. They just seem to dice and food falls apart. I still need to slice to cut my food. And I finish at 9u before stropping with compound and my edges are mirrors.
