I'm learning a lot from this thread, especially Stacy's recent summation. If I am to interpret correctly, the consensus is a thinner geometry, martensite edge, fine pearlite transition, from slow a drawback blade will yield better under lateral stress? If this is true, than a thinner blade (possible 3/16" or thinner) with a wider profile fully hardened and then drawn back....would be the best bet for the J.S. performance test?
I think that is a fair statement. The idea behind the JS Performance test is to see if the maker has control of heat. You can shoot for a blade that returns back to true after a 90deg flex, but as Kevin so bluntly put it to me, "WHY?... there are no extra points for wow-factor.". If the only goal of the 90deg flex test is to not have your blade break, why would you risk it by fighting the yield point? Temper that baby back! I feel it is just as bad to have the mixed structure of a differential HT that in essence, creates a place for failure to begin. I see blades that crack at the edge and bend at the spine and yes, they will pass if the crack is less than 1/3 of the blade width. BUT why not have a blade that yields without cracking at all? Fully martensitic, tempered accordingly is the way to go, IMHO.
