)))))))) Edge Renewal Utility ((((((((
Fred.Rowe
Feedback: +15 / =0 / -0
Why establish a flat edge?
The ERU, with its precise "V" works with a "flat" edge. If you try sharpening a convex edge with an ERU it doesn't work. The carbide surfaces make contact, above the apex, along the shoulders above the edge. This would be true when trying to sharpen a convex edge thats been ground on a belt machine using a slake belt. These convex edges are the only edges that are truly convex, [they curve all the way from the shoulders clear through the apex.
Convex edges that are turned out on a stone or diamond plate are not really convex. Because of the free hand technique used to produce them, the apex and the area directly behind the apex are actually flat, with the area at the shoulders being "rounded" or convex. The cutting edge is flat with a slight curvature across the shoulders of the edge.
This type of edge can be sharpened with an ERU because the apex itself is flat and the ERU's precise angle settings will match right up. It can be a micro bevel as well on this type of edge.
To help in producing a flat edge, a set of accurate degrees wedges are included with the ERU. The degree wedges come in 8-10-12-14-15-16-17-18-20. This makes putting a "flat" edge on you knife easy and quite accurate. Using the ERU in combination with the degree wedges and your stone or plate makes producing and maintaining a flat edge not only possible, but easy and reproducible.
Makers who use the Bubble Jig to sharpen, establishing a flat edge on the platen area, can then follow the belt made edge with an ERU set at a corresponding angle. There are quite a few makers that are using this technique to produce the edges on there newly built knives. It is extremely accurate and can be used to reproduced and maintain the desired edge.
The "flat edge" is IMHO the easiest edge to establish and maintain with this simple equipment and easy technique.
Post any comments you might have, always glad to hear from other makers, Fred
[video=youtube_share;fZYZGqjB2us]http://youtu.be/fZYZGqjB2us[/video]
The ERU comes with a full set of sharpening wedges, shown in the photo. Use these degree wedges to establish a "flat" edge bevel before switching to the ERU to finish the edge. Truly flat edges can be profiled and set in very short time using a diamond plate or a water or oil stone followed by removal of the wire edge with the ERU. Once an edge is made flat its easy to maintain with the ERU super "V" sharpener.
Its a great tool to use to find the actual edge angle of your knife as well as keeping the edge sharp
ugY1KN0_3sQveEOv7nftoSkqP5BUQ4I8zhaupDsaLD4=w671-h575-no
The ERU field sharpener is the most precise sharpener on the market today. infinitely adjustable between 12 and 40 degrees and it fits in the palm of your hand.
They come with an alignment pin, a set of 8 degree wedges to use with your sharpening stone or diamond plate, to help in producing a truly flat edge, along with a hand stitched leather sheath.
This precision tool is for sale on our website ERU
Take time to watch the DVD, I think it explains pretty well, how it works and why it works so well. You would never believe a "V" style sharpener could do what this tool does.
Send me a PM if interested. I ship next day. The website is just about ready to post on line, watch for us.
[video=youtube_share;jJsSkD8GE0g]http://youtu.be/jJsSkD8GE0g[/video]
0
Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Join DateAug 2004LocationNorfolk,Va.Posts19,394Feedback Score7 (100%)​
Mine came the other day.
Well packed with all the things needed to make it easy to use. The DVD explains what isn't intuitive.
I had participated in the original product testing of this device, and the improvements from the prototype are good. If you go where a set of stones or a belt grinder isn't going to be available, this will be the thing to take. Additionally, it will be just the right tool to touch up an edge during game dressing or filleting fish anywhere. I think the non-knifemaker folks can finally buy a knife with a good edge and keep it shaving sharp with an ERU.
Don't even think of comparing this to one of those small "key chain" carbide sharpeners or mini-crock stix fobs. There is no comparison. The ERU is to one of those as a TW-90 is to an HF1X30.
The above is my real feelings. Fred knows that I am not a huge fan of gadgets and jigs. These devices rarely take the place of learned skills. I have probably $10,000 in sharpening tools and supplies. I bough one of these ( yep, I paid the same price as everyone else) because it works when those big boy toys aren't with me. I put this right in the car. Next time I am at a friend's home for dinner and the knives need a touch up to carve a roast...out the ERU will come.
Final note. Grinding bevels and sharpening problems are where most new makers get disgusted and quit. I have seem pretty knives with lousy grinds, and good grinds with terrible edges. Fred's Bubble jig and now the ERU are two tools that will help anyone from novice to pro make and maintain superb bevels and edges. Neither will replace practice and skill ( and are not intended to). Both will make learning those skills faster and the results much more consistent.​
