- Jul 23, 2007
Perhaps if I knew what a super steel is I could answer the question.
Sorry for use of layman terms lol
I was talking about high carbide steels like s30v, m390 etc
I'm not sure that anything he used could be called a control, but to be fair I'm not sure what a valid control would be.Once again, thank you for presenting this work. I had long wondered about Dr. Landes thesis, and again I find myself wondering...
Perhaps you can help me with a few specific questions:
1) What "controls" are included, positive or negative, to give context to the values?
I don't have answers to those questions other than he apparently did do some tests with 10 degree edges that were not published.2) What was the reasoning behind 20' inclusive vs 10' or 30'?
3) What was the reasoning behind the selection of steel-types and HT-parameters tested?
The values are different for a few reasons:4) Crucible estimates the carbide volume of 154CM (version of ATS34, iirc) at 17.5% but your charts place it at ~12.5%?
I do not have answers to those questions.5) How does a value of 0.02 vs 0.04 translate to observed edge performance? Do these results themselves have any real-world application? Is there a specific real-world use in which applied stress to a knife edge is likely to compromise a 0.02-scoring knife but remain below what is required to compromise a 0.04-scoring knife, or is the laboratory the only place where one may ever encounter such distinction between applied forces? I do not have a good sense of how much more force a 0.04-edge can endure vs a 0.02-edge.
I provided some of Roman's own answers to questions I posed in the article. Some answers are more satisfying than others. I think it is better to let him defend himself.6) How does Landes justify his bias against the high ATS34 results? If he tested over 1 cm of edge and the average result surpassed his expectations and presented a low CV, how can he question it without holding the rest of his tests to the same standard? For example, if the ATS34 results are suspect, are not also the result of the 1.174 steel?
As I said in the article there was no clear trend with carbide volume in terms of the edge stability test. If we are generous I would say that Roman's "edge stability test" and "edge stability theory" are not necessarily one and the same. The theory was developed after the thesis so the results wouldn't have surprised him in terms of discounting his theory. Along with Roman we decided that the best approach was to have an article summarizing his theory and then to have the second article analyzing the original experiments. My plan is to perform impact testing of edges and come to my own conclusions.My conclusion from these results would be that, contrary to rumor from some circles, carbide volumes between 0 & 20% is likely to have no discernible impact on edge-performance in terms of edge-stability.
Based on your attestation of Landes' bias against high-carbide steels, I assume that the results surprised him. Once again, I woul dbe very interested to see the experiment repeated using tungsten-carbide diatome blades...
Strength isn’t really a resistance to breaking as much as it is a resistance to deformation.
To my mind, one obvious control would be a W-Co blade - this is exceedingly common in cutting tools and can present a much higher Rc value than steel as well as much higher carbide content with very low impact toughness at low Co concentrations. Because W-Co can achieve apex-diameters well below anything attainable with steel, it is an obvious choice as a control for extreme edge-stability, imho.I'm not sure that anything he used could be called a control, but to be fair I'm not sure what a valid control would be.
It would be interesting to see at 10' and 30' given that 30' is the typical sharpening angle recommended for the final edge on everything from chainsaws and axes to razor blades and 10' is the typical primary-bevel angle on many American knives, a show of what would happen if you DIDN'T cut secondary the edge-bevelI don't have answers to those questions other than he apparently did do some tests with 10 degree edges that were not published.
You may not wish to bother, but I am curious if you would be willing to present a modified version of the graph with different carbide % according to, for example, the values presented (albeit without clear explanation) from the steel-makers? Obviously this might be obnoxious to bother with, but what would your R^2 value be for the carbide-volume graphs vs edge-stability and Hardness if you moved just the ATS-34 value from 12.5 to 17.5% ?The values are different for a few reasons:...
Understandable....
That would indeed be "generous". The lack of a trend is quite significant in that it strongly supports the null-hypothesis - carbide volume (in these steels, volume%, with these HT-protocols) does not impact "edge stability".As I said in the article there was no clear trend with carbide volume in terms of the edge stability test. If we are generous I would say that Roman's "edge stability test" and "edge stability theory" are not necessarily one and the same. The theory was developed after the thesis so the results wouldn't have surprised him in terms of discounting his theory. Along with Roman we decided that the best approach was to have an article summarizing his theory and then to have the second article analyzing the original experiments. My plan is to perform impact testing of edges and come to my own conclusions.
The majority of the steels used don't have an experimentally measured carbide volume that I know of, hence the use of calculations. Here is a graph for a different set of steels that I do have experimental values for. The chart is from an unpublished article.You may not wish to bother, but I am curious if you would be willing to present a modified version of the graph with different carbide % according to, for example, the values presented (albeit without clear explanation) from the steel-makers? Obviously this might be obnoxious to bother with, but what would your R^2 value be for the carbide-volume graphs vs edge-stability and Hardness if you moved just the ATS-34 value from 12.5 to 17.5% ?
This is what I wrote:On a different note, you linked in your article another on 'Sharpness vs Cutting Ability', and i was curious as to why you did not bring up "mechanical advantage" ad the role that played in your CATRA experiment changing edge-angles? Perhaps i should post this next part in a thread on that article? You show in that article that apex-width correlates directly to penetration-force, but I felt that you did not further illustrate that this initial fact is also the explanation for the force required for the rest of the cut (what you refer to as 'cutting ability'), i.e. that the edge-width at any given depth back from the initiation of the cut by the apex is part of the wedge/ramp forcing its way through the material. It is this simple principle that accounts for the difference in CATRA performance between the 20' and 50' edges as I mentioned in your CATRA thread, it explains why the 50' edge was not allowed to cut more and so degrade its edge more.
