EdgePro Polish Tapes
Are the EdgePro 1000 and 3000 polish tapes just for polishing or can they be used to sharpen an edge? Can they make the edge measurably sharper?
They remove steel from the edge, so, yes, they sharpen. It's more noticeable on push-cutting and chopping, though if your edges are very thin, you'll also notice an increased ability to make very thin slices.
I use mine to sharpen, and in most cases I see an improvement. Occasionally, I still get a knife that for some reason, the tapes seem to dull the edge a little. So I'll just make a pass on either side with the 600g stone, and it will bring the edge back.
cbw
When that happens, eventually I resharpen the knife and make s-sure (I'm stuttering online. great.... :o ) I use less pressure than the weight of the movement arm when I get to the tapes (if the arm presses down with 2oz. because of pesky gravity, I apply resistance so maybe only half that weight is on the edge; well, then the force of moving the arm itself in a parallel plane has to be reduced, too, so I end up barely balancing the stone/tape arm on the tips of my fingers as I sharpen).
Before, that, though, I steal C-Dawg and Ken123's idea and strop over glass with paper dotted with 0.5 micron diamond paste. As was said of such edges in the book of Edgeclesiastes: Mmmm nasty!
