Hi guy, I'm starting a EERF grinder build . I have the plans at the laser cutters at the moment , to be cut out of 12mm plate because that's the closest we have in metric here.
I plan on running a multi plattern with 4 inch and 8 inch wheels. I have added the multiple spaces similar to the grinder in a box to allow for a work rest .But there maybe other differences apart from the idler arm being 2 inches higher.
The motor will be 2hp one with a 6 inch drive wheel to allow for the 50hz power we have here, that will only spin the 2hp motor to 2850rpm. I also plan on running a vfd that will run up to 130% or as low as 50%.
So does any one know if a 1520mm (59.8 inch) belt will run on such a setup or if 2440mm (96inch) belt would be way too big realistically?
I can get custom belts made if needed with a 2 week turnaround.
Any improvements or concerns would be appreciated.
Thank you for you time guys - Wayne
