Brian.Evans
Registered Member
- Aug 20, 2011
Now cut out five more spacers and two more end plates and make it a double arm. Look at the GIB website for what I'm talking about.
center of all wheels should be in the same plane.
12/3 cord will be just fine for that 1 hp motor since you run is less than 25 ft, heck, it'd even work just fine for 30 ft or so. Don't short yourself on cord length.
I would think at least half drive wheel should be on shaft - at least enough for the set screw to clamp good.
until you decide to mount the second arm, you can always bolt your tool rest to bottom of existing 1.5" arm - that's how I do it, and works just fine.
Your build is progressing nicely, and you're going to be PROUD of that grinder.
Ken H>
$300 total? You da man! I've got around $400 in my new grinder including 2hp motor and VFD. For the 1.5" "box" to hold the tooling arm I used 2.5" and 1.5" X 1/2" thick aluminum bar stock to built it. Works like a champ, and I like working with aluminum.. I saw somewhere a guy was using his milling machine to turn a pulley. With the hole drilled in center of round stock, then an arbor holding the round stock and chucked in mill, a lathe tool clamped to bed of mill, he turned the pulley slick as a whistle. I don't remember all the details.
Ken H>
cab tire (soow, sjoow) lists the ground as a conductor, 12/3 will have 3 wires in there. Every other type of wire (teck, NMD, BX, etc) a 12/3 will have 4. This is probably because in the cab tire the ground is insulated, and the same gauge wire as the conductors. In regular wire its uninsulated and one size smaller. 12/3 teck will have a 14 gauge ground, for a total of 4 wires.
The wire you would probably use for the motor is cab tire, its the rubbery stuff that you use for extension cords. So you should get a 12/4 cab tire from vfd to motor so you can ground the motor.
I am probably answering an unasked question, but there it is anyways.
4 conductors are understood from VFD to motor. From reading his question I assumed (yea, I know "ass-u-me"), he was asking about from recept to VFD. In a pinch, you could use 3/C from VFD to motor, AND use a 1/C from motor to VFD for ground. BUT - YOU DO NEED the ground for safety.
Ken H>
