kevin, are you saying that if I normalize correctly prior to quenching that the benefit of multiple quenches is minimal? I've never tried to inentionally overheat steel to see what the grain size was like. Of the knives I've broken, the difference in grain size didn't seem much different whether I quenched once or 3 times. I always figured it was just inexperience in telling the difference, which is a factor for me regardless.
As I understand it, "triple quenching"--as in triple hardening--just induces unnecessary stresses as the austenite converts to martensite...
...You cannot over normalize but you can overheat the steel and increase the grain size...
Actaully with steels like 10XX series and W series you can make it harder on yourself in the final hardening by too much normalizing. With shallow hardening steels increasingly finer grain could lower hardenability to the point that only water or brine will get you there. Also improper cycling will increase segregation and carbide coarsening which will also lower hardenability and have profound affects on the final product.
look at the difference in grain refinement in one heat of the L6 versus the 1084 in two! When you have alloying and carbides in the mix everything changes.
Now I understand when some say "add vanadium to help grain refinement".
...(this is not a referrence to you at all mstephen, this is the first time I have seen your input on the topic and I applaud your experimentation and desire to see what happens)....
