BP_
Platinum Member
- Aug 26, 2015
Finally got my Companion in the mail the other day, had a chance to carry it around a few days, and thought I would share my initial thoughts.
It is advertised as sharp right out of the box, as a good knife should be. So the first thing I did, of course, was take it out of the box and gave it a stroke down my arm. Gotta say, she came just as advertised! This little thing is sharp and took the hair right off with ease.
The first thing I noticed was the grooves on the top of the blade, which are comfortable and provide a little "useable" extra grip, not just for show. It really cuts very well, and the ergonomics actually lend itself to that of a bigger knife in my opinion. At 6" OAL, I was curious to see how it would feel in my hand, and how confident I would be to use it as an every day knife. I was impressed.
The F&F is ideal for an everyday user in my opinion, it looks and feels like it wants to work for you. The blade has a nice sweep up at the tip that really gives it a "user" look to my eye. S35VN steel, full tang.
I chose the black scales (CF on the way!), and they blend well with the exposed tang. It's a slim knife, but feels solid in hand. Has a lanyard hole that's shaped on the bottom end with the scales, which I really like (I'm a lanyard guy), and because I carry around my neck or scout style will be beneficial (waiting on the new scales to come [emoji38]).
I work in a warehouse environment, and do a multitude of things throughout my day. I used it to cut paper, cardboard, plastic, up to 5/8" rubber hose, packing tape, rope, and had it stuck in wood (wooden pallets). Oh, and just for fun, I stuck it through a few old tires as well [emoji16]
After two ten hour day shifts in the warehouse, I came home and decided I would do a little feathering out in the yard. Gave the first solid looking stick I found a good hundred or so strokes, just to make sure I was giving it enough time to break in properly, and figured I would try shaving a little hair off my arm again. If it was sharp enough, that is. Three strokes later and I was convinced I could probably shave my whole arm if I wanted to.
I have only had it a few days, but overall I would have to say it's a solid little knife. If you're not into smaller fixed blades, it might not be your cup of tea, but it's a nice knife and feels solid without the bulk. It's made well, and it's extremely sharp. Small, but very capable, and comfortable in hand. It's a nice EDC because it's lightweight, slim, but every bit as capable as any of the other knives I carry, if not more. I usually carry three knives, and I found this one being my default "go to" when I needed to grab one. It's just comfortable, and sharp enough to cut anything I would put in front of it (I'll add I'm not a master sharpener by any means, but I keep my EDC knives pretty darn sharp). Out of the box, this one stands right up next to all the others I use. This knife is a user, and that's the way I like 'em.
Mr. Evans you make an excellent knife, and are truly a great guy to work and converse with! Thank you.
(my apologies for the lack of photography skills, these are some good old phone pics)
