A friend built one to that design and I did the control stuff on it. Then I built one myself with a couple of changes. I've built 5 now, each one, hopefully, slightly better than the last.
There are a only really a few things I did differently.
I made it slightly bigger; there's about 1/2"-3/4" of brick below the bottom element on mine, which lessens the chances of nudging a workpiece (or rack) into the element. I also made it slightly longer, using 5 bricks in the main structure, not 4, to give an 18" working length. I'm pretty sure you could go to 22.5" with 3 kW of elements if you use Thermal Ceramics JM23 or K23 IFBs. These are only made in Italy and the USA, so are expensive here in the UK. I'd expect them to be readily available in the US. The ones Andy Gascoigne used look like one of the denser, cheaper, types also available here. Thermal mass is greater, which slows down heating, and the insulation value is lower, limiting the maximum temperature. I used the cheap ones in my first HT oven, but spent the extra on the later ones.
There was some confusion over the elements used: Andy used 2 elements, each rated for 14A and 115V, connected in series for the 230V supply in the UK. BCS later also listed a 14A, 230V element, and at least one builder made the mistake of connecting 2 of these in series and couldn't reach temperature. Make sure you get the right ones.
I regard a ramp/soak controller as pretty much essential. I use an Omega CN8723
http://www.omega.com/ppt/pptsc.asp?ref=CN7800&Nav=vhpa04 mainly because they are available here.
The Auber ramp/soak controller looks like it'll get the job done, but I've not used it myself.
Using a slow ramp effectively eliminates overshoot and radiative heating issues, very important when tempering. It's also very useful for stainless steels with 2-step heating recommendations to Austenitizing. A more basic PID controller is fine if you are only going to be using the oven for Austenitizing "simpler" Carbon steels and use another oven for tempering. I use type N thermocouples, rather than type K, because they are more stable at high temperatures, and use Mineral-Insulated assemblies, rather than bare-wire. I'd suggest talking to Omega; they seem very knowledgable, very patient and give good advice, at least here in the UK.
I use a "Fotek" branded SSR bought off ebay (cheap). I use a 25A and I've had no problems. I've seen recommendations for oversizing the SSR (40A), but I'm pretty sure oversizing its heatsink is more helpful than oversizing the SSR itself. By all means oversize both if you wish.
I use a 2-second switching cycle for the controller output. I've had a datalogger on the oven and 2 seconds is noticably better than 5 seconds. I can't measure any advantage in going down to one second.
We have a 230V "hot" leg here and the Neutral is at ground potential; things are different enough that I can't really advise on electrics for the US.
I use a door switch. It seems safer and is pretty cheap.
Make sure the door can be opened and closed with one gloved hand if there is any chance you'll be treating multiple blades. I use Ceramic Fiber blanket for the door seal and getting the compression with one-handed closing took a little thought and experimentation.
There have been one or two element failures reported on BritishBlades (one of them was on one of "my" ovens). The jury is still out on whether the stainless steel allthread is the best way to connect the elements, or if it's better to take the element "tails" out through the brick and use a ceramic terminal bock on the outside. Either way, it's probably wise to make it as easy as you can to change the elements: I fully welded the frames on all of mine and now consider it a mistake.
I cut the element grooves in the first two with a saw and finish-filed them with allthread. It wasn't difficult, but got pretty tedious. I used a router on the later ones; much easier and quicker. Neater too.
It's worth following the various links from
http://www.britishblades.com/forums...ng-a-Heat-Treatment-Oven-Information-Database
Many of the ovens linked to are largely based on Andy Gascoigne's design.
I hope you enjoy building yours as much as I did mine.
Tim
