- Aug 5, 2014
I'm looking to make a more advanced version of my electric Heat Treat oven and have several questions and was hoping some members here could give me some feedback. I was inspired by JT's thread on his oven build with the coils wrapped around ceramic rods inside of quartz tubing - seems like a badass setup
I know that some people consider the extra features here to be a bit overbuilt, but that's ok by me - I consider these builds to be a lot of fun
) Any help is much appreciated!
1) First, I'd also like to do the coils wrapped around ceramic rod inside of the quartz tubing. I plan to use 13 gauge wire. If I'm wrapping coils around a rod of approximately 1/2" diameter, what size quartz tubing should I get and what approximate wall thickness? I see a lot in the range of 1.5-2mm wall thickness. is that enough? I can also go larger on the ceramic rod if needed too.
2) This is more specifically for JT (but if anyone else knows, also helpful) - in your build with the coils suspended from the ceiling, does it heat fairly evenly throughout the oven or does it tend to heat the edge of the blade a lot faster than the rest? Do you think it would it be better to run the coils along the walls or is the ceiling fine? I can get the quartz as long as 1 meter (39 inches).
3) Door design - is it best to have the hinge at the bottom, side, or top of the door? Also, I'm interested in some kind of hands-free system for the door and was thinking of some kind of cantilever system that can be pressed by foot, if it's not too inconvenient. Any ideas? Or better to just use a handle....
4) I'm also very interested in the "Viewing window" that was discussed on here using round quartz plate glass. I've found sizes 20x2mm, 20x3mm, and 15x5mm and am planning on having 2 round plates set apart, mortared into the brick, with an insulated flap on the outside on a hinge. Curious if any of those sizes/thicknesses of quartz glass sound better than the other. Generally, I'd guess that thinner will insulate heat better so perhaps the 2 or 3mm?
I think that's it for now, thank you much for any feedback given!
