- Sep 2, 2004
Is anyone successful in using a long oven, like a Paragon 36km, in heat treating long blades? I've been fighting mine for years, trying different solutions but running into the same issue. I basically cannot get an even heat down the blade. If I pull the blade after a soak, the tip area is much hotter than the tang. Since the tip goes in first, toward the back of the oven, I think that because the heating elements wrap around the back wall, it's just naturally going to be hotter down there than up towards the door area, where the elements do not wrap around. There is a noticeable graduation of heat down the blade that I would guess being a difference of 100 degrees or more, which is not acceptable. I've tried moving the thermocouple down towards the far end, which keeps that end from getting too hot, but then the tang end is too cool. I've heard of others letting their oven run for an hour before heat treating, to equalize temps, might try that too.
Anyway, just wondered if this oven is headed for paper weight heaven.
Dan
Dan
