I've been collecting parts for a grinder and got around to wiring up my 1.5HP motor and KB VFD this weekend. I'm getting really bad vibrations at any setting below 60Hz (50% speed with the 2X option enabled, 100% in regular mode)
Of course, I've searched for answers and found the following threads, none of which have an real solutions:
http://www.bladeforums.com/forums/s...D-saga-goes-on-!?highlight=KBAC-27D+vibration
http://www.bladeforums.com/forums/s...ith-VFD-KBAC-27D?highlight=KBAC-27D+vibration
The motor is not mechanically out of balance since it runs smooth as can be at full speed. I tried adjusting the CL and COMP trimpots to no avail. The motor is completely unloaded.
My setup (All parts are new):
KBAC-27D on 115V (20A circuit)
Hallmark 1.5HP 1725RPM TEFC 56c motor
All wiring is 12AWG (12/3 for the plug, 12/4 to the motor) The motor chassis ground is tied to the VFD chassis ground which is tied to the house ground.
Any suggestions? This VFD seems to be "the standard" so I'm a bit surprised to be having problems with it. Sadly, I do not have a second motor to test with.
Thanks!
-Matt
Thanks!
-Matt
