- Aug 15, 2020
Hey guys I was just servicing my Emerson combat KaramBit that is now 6 years old when I noticed that compared to almost all my other knives it has a lot more resistance when trying to open it. And to be fair it always had this problem where I could never really open it one-handed and I always had to use the wave feature
To put this in perspective by Spyderco can be open with one finger using the thumb hole as though I’m shooting a marble with my thumb or can be opened by the wave.
however the Emersons thumb hole can basically not be utilized because you can’t flick the blade open with just your fingers.
The only way you can truly open it is by starting it with your thumb and then whipping your hand.
I’m wondering if the lubrication has become an issue or maybe my pivot screw is too tight.
All I know is that at this point you either need to use two hands to open the blade or if you’re doing it with one hand you need to start it just a little bit by hand and then flick it open the rest of the way.
Based on other peoples posts I think I may have done some thing and it’s early days 4-5 years ago and might’ve adjusted the tension By tightening it loosening the pivot screw.
but somehow I always remember that even when I used to loosen the pivot screw up almost all the way it’s still never really loosened up to the point that I wanted it to.
Either you can loosen the pivot screw to the point where I just falls open or you can tighten it and then it becomes very stiff
Any
ideas ?
Any
ideas ?
