I put pencil lead on the lockbar and now it slips off with the least pressure just like it did before.
Well, DUH! Pencil "lead" is not lead - it's graphite, which is a LUBRICANT..........
I'm just reading the thread like you. I have heard this stuff for years so I'm sure there is some validity to it. As for myself, I have yet to own a knife with a spine so sharp it could cut so I indeed use the side that is sharp.<shaking my head>
My former neighbor had a linerlock (won't name the brand) and the third or fourth day he used it the lock slipped and bit him pretty good. The day he got the knife I told him I didn't like the look of the lockup, it was "stupid early". He was as new to knives as one can be so I can guarantee you he didn't try to whittle with the spine side, only experts use that side. Heh. I'm not an expert. Maybe one day I'll reach that elite level.
The way he explained it to me was that he was just carving on a stick and when he followed through on the cutting stroke he didn't clear the piece of wood enough and the tip part of his knife (on the spine end)....hit the wood - I'm sure you can figure it out if you think about. I've had that scenario happen to me so many times I couldn't count them but never with enough pressure or sucky lockup to disengage the blade itself. He'd have no reason to make it up and only experts spine whack their knives.
yes I know it is graphite.
Maybe you are not aware that using pencil lead on a lockbar is common practice. Most people do this because of sticky locks. But it should not cause a lock to slip.
Why do I even bother? You said you put it on a slipping lock, and then complained because it slipped more.....
This is why I usually avoid BF - way too much lack of common sense here. Ugh.
the geometry of the lock pretty much ensures the majority of the force is driven parallel to the blade, and not to the side of the knife to disengage the lock.
I'm curious if this is endemic to a certain model year... My 2011 and 2013 knives have had absolutely no problems and I have as much confidence in them as I should with a liner lock... Only my 2012 model has an issue -- a 2012 horseman with super early lockup... it looked suspicious and sure enough it closed on me. Upon further investigation the lock continuously fails with light/medium pressure on the spine. I am planning on sending it in to Emerson.
I've never had a problem with the locks on any that I've had, even on brand new ones with really early lockup. They break in nicely with use.
