- Mar 31, 2010
I carry a knife as a backup weapon, so any advantage my knife can give me is welcomed. A lot of the bad guys down here use body armor, so having a blade that can defeat body armor is something I look for in a blade.
I have edge weapons training and know about all the good un protected targets on the body, y also have enough experience to now that all that training sometimes goes out the window when you find yourself in an extreme CQC situation.
I recently got to met and talk to Mr. Ernest Emerson at the California Custom Knife show, he really is a very well versed combat instructor, experienced fighter and a genius knife maker. I show him the Bedlam 860 I carry, and he proceeded to explain to me the advantages that the Persian has over the Bedlam as far as penetrating heavy clothing or body armor. This knife is made for people plain and simple he told me. The only other knife I can compeer the tip of the Persian with is the Hissatsu folder.
Neutralizing an active attacker with a deep stab is what I go for in an extreme CQC type situation, so penetration is a very big factor for me. There are many opinions stabbing vs. slashing as a fight stopper.
This test is to compare stabbing capability against Kevlar.
I used a level IIIA Kevlar vest for this test. This vest is not made to protect against piercing weapons, but some knives penetrated deeper than others on it depending on the shape of the blade; imagine trying to stab a moving target or one that is actively attacking you, its harder than it seems. There is also this thin plastic coating that some of the newer vest have that actually do make it a bit harder to penetrate.
I did a full force stab to the center of the vest using a reverse grip wile I supported the bottom of it.
First some info on the knives.
Benchmade Bedlam 860
Blade length: 3.95
Overall length: 9.71
Blade material: 154CM Stainless Steel
Blade style; Modified Bowie with Ambidextrous Thumb-Studs
Locking mechanism: Axis lock
Pocket Clip: Tip-Up, Reversible
Emerson Persian
Blade length: 4.10
Overall length: 9.60
Blade material: 154 CM
Blade style: Persian style, v grind blade
Locking mechanism: Titanium liner lock
Pocket Clip: Tip-Up
First up, the BM Bedlam 860.
The knife itself felt very solid when it went through the vest, but I did feel the knife as it stopped mid stab, leaving only half of the blade inside the target.
Next up, the Emerson Persian.
A very solid grip and feeling as it went through the vest, I did not feel any resistance at all as it went in, it only stopped going through because of the thumb stud.
The Persian is the clear winner in this test; you can see the back of the vest in this picture. The top one is the Persian and the bottom one the Bedlam.
They both are very good blades, I think the Bedlam is more of a multiple use knife, the Persian all weapon.
