Emerson Timberline SPECWAR, some faint marks on the right side of the blade.
CONUS only
The SPECWAR is made of 60Rc, ATS34. The handle is made of Grivory, which is a thermoplastic cross that has some flexibility and hardness while being non-conductive and heat resistant."
"The knife was deigned with Prying, insulated cutting, chopping, swing cutting and light hammering, in that order of priority."
"The 304 stainless steel pommel is not attached to the blade but can be used for light hammering, but will not conduct electricity from the blade."
"Ernest Emerson and Timberlines Vaugh Neely collaborated on the Timberline Specwar and was made in Timberlines Colorado Facility using hadnmade techniques to get it right."
"The handle material was non conductive and impervious to everything including heat, and chemicals. The coating on the blade was not a corrosion resistant coating. It was a wear resistant coating that was reputed to be a Rockwell hardness of 80-90. Harder than even Chrome. The edge was chisel like all the emerson specwars."
Specifications:
3/16" blade thickness and 1 3/8" blade depth. False top edge. Chisel grind Tanto.
Product Details:
Blade material: ATS-34 - Black-Ti Coated @ 60 RC
Blade size: 5 1/2" Cutting Edge
Handle: Fiberglass Reinforced Nylon
Overall: 11 7/8"
Sheath: Kydex / Nylon Web Sheath
Interested:
Emerson CQC-12 BT
Emerson CQC-8 BT
Emerson Roadhouse PE
Spyderco black Warrior
MOLLE compatible pouches in Multicam and Coyote and high quality AR magazines.
CONUS only
Specifications:
Product Details:
Overall: 11 7/8"
Interested:
Emerson CQC-12 BT
Emerson CQC-8 BT
