ENDED - Two unique carbon steel knives, made for using
David Mary
pass the mustard - after you cut it
Moderator
Feedback: +136 / =0 / -0
Modified Clip Point
Here is a highly functional knife with a very good weight to size and strength ratio, and a unique handle construction. This knife is grippy in the hand, very nicely balanced for easy use, and thinly ground for great cutting performance.
Specs
Steel: .156" 8670
Geometry: Full flatvex grind, .008" behind the edge, with the tip being a little more robust, at .020" behind the edge.
Overall Length: 9"
Cutting Edge Length: 5 1/2"
Weight: 5.4 oz., 6.8 oz. with sheath
Handle: dark red Suretouch bolster segment, cherry red Suretouch spacers, carbon fiber central segment, and cherry red Suretouch rear segment with green G10 liners.
Suretouch is an ingenious handle material, which consists of colored G10 laminated with durable and grippy black rubber, combining the best qualities of both materials. You will find that Suretouch has great grip, even when smooth. I find that even a smooth Suretouch handle feels like it is glued into place in my hand, even while wearing slippery gloves or mittens. Suretouch also has a very slight amount of give to it so that it does not feel as rock hard in the hand as straight G10, adding further to the handle's comfortable feel.
Sheath: Black twill pattern Holstex taco sheath included, compatible with Tek-locks and most adjustable clips on the market.
Holstex is a thermoplastic like Kydex, but with an artistic design molded into the outer surface. It has the same durability and resistance to the elements as Kydex.
Price is expired, payable via itemized PayPal invoice, which I will send to your specified email address. Includes tracked and insured expedited North America shipping. I will ship internationally at buyer's expense and liability. First "I'll take it" with comms by PM or email (ie send me the email address you want the invoice sent to) gets priority. My email address is in my sig if you turn your phone sideways. Combined shipping saves $15 per extra item.
Serrated EDC
Here is a light and fast serrated knife with a highly grippy handle, secure minimalist sheath, and no guard whatsoever. Expert level EDC I call these types of knives. If you are clumsy in your knife use, don't take this one or you are liable to cut yourself up! Has subtle irregularities visible on the flat side of the blade, evidence of its forge heat treatment; will not affect function at all.
Specs
Steel: .09" 15N20
Geometry: Right hand chisel saber flatvex serrated grind, averaging ~.012" behind the edge.
Overall Length: 7 1/2"
Cutting Edge Length: 3 1/2"
Weight: 2.5 oz., 3.4 oz. with sheath
Handle: OD Suretouch with brown G10 liners.
Sheath: Black Boltaron taco sheath included, compatible with Tek-locks and most adjustable clips on the market.
Boltaron is a thermoplastic like Kydex, similar in price, but with a molding temperature about 30° higher than Kydex. This means that it is functionally identical to Kydex in all climates except that in high temperature climates it is a far superior choice, as it is much less likely to lose its shape if left in a hot car, for example. The only drawback to Boltaron over Kydex is it is available in fewer colors.
Thank you for looking
