- Sep 27, 2008
This Cutter was used 3 times and works as it did when it was new. I'll Take 350.00 pay paled (gift) and shipped.
SPECS:
Cutting speed up to 15ips
• Cutting force up to 250 grams
• Stepper drive motor
• Precise tracking up to 8 feet
• Economical choice for basic small to medium format graphics
• More specifications below
Perfect machine to start your vinyl sign business or an economical back-up for your existing vinyl cutter. This desktop vinyl sign cutter is great for short run graphics!
See examples
Windows OS compatible only
Specifications:
• Operational Method: Friction Feed
• Max. Cutting Area: 23.75" / 603 mm
• Acceptable Material Size: 28.3" / 719 mm
• Acceptable Material Thickness: 15mil (.015"/0.38mm)
• Drive: Stepper Motor
• Cutting Force: 250 grams
• Max Cutting Speed: 16 in/sec; 400 mm/sec;
• Pinch Roller Position Sensors
• Software Resolution: 0.025 mm
• Repeatability: 0.1 mm
• Re-plot Memory: 500 kb
• Interfaces: RS-232S
• Commands: HP-GL
• Configurable Origin: Yes
• Control Panel: 6 LEDs / 10 Keys
• Commands: HP-GL
• Operational Environment:
Temperature: 10ºC ~ 35º / 50ºF ~ 95ºF;
Humidity: 25% - 75%
• Dimensions (H x W x D): 8.67" x 34.61" x 10.16";
220mm x 879mm x 258mm
• Weight: 24.69 lbs; 11.2 kg
SPECS:
See examples
Specifications:
• Commands: HP-GL
• Commands: HP-GL
Humidity: 25% - 75%
