- Mar 21, 2005
I'd put it in 2nd place behind the Groove but ahead of the JYD2. For me the Groove is easier than the JYD2. Not to say the JYD2 was hard to flip open in any way, quite the opposite in fact, but the thinner, pointier flipper on the Groove just works better for me.
For opening with no wrist action at all, I'd put it this way. On the Groove, I can put the pad of my index finger on the top point of the flipper and push from there to open the knife. Alternately, I can put the same finger, from the tip to the first knuckle, on one side of the flipper and pull it back along the top of the frame to open. Either way works fine for me. With the JYD2, I found the most reliable way was to use the second method, what I believe Kershaw describes as the straight line pull in the leaflet that comes with the knives.
On the ENER-G, the flipper tab is not as round as the JYD2 and not as pointy as the Groove. It works very well with the straight line pull, but not necessarily as well with pushing directly down (perpendicular to the frame rather than parallel along it) on flipper. My impression is that having the follow through of the straight line pull is the best method on the ENER-G. It's a very slick system, and it doesn't seem that anything is lost mechanically by having the tab separate from the blade. I may try loosening the pivot a bit on the ENER-G to see what kind of a difference it makes, if the initial force needed to break the detent can be modified while still getting the same opening speed.
Again, this is all for opening with no wrist action. On any of these knives just a slight wrist move will produce a full, solid opening.
