- Jul 22, 2013
I am selling all of my knifemaking equipment that I have accumulated over the past 4+ years. It is everything you would need to start making knives from day 1. Grinder package, heat treat oven, drill press, portaband w/swag table, disc sander, multiples buffers, mini mill, handle material, blade material, folding knife hardware, Titanium, grinding jigs, etc.... Over $18K invested in this lot, not counting all the belts, titanium, blade steel, folding knife hardware, etc...
Not going to split up at this time. Must pickup near Pittsburgh, Pa.
Asking $12K
All inquires DM me please.
Evenheat KH18 Kiln (Cost $2,357)
Folding Knife Hardware
Wilson Rockwell tester with new diamond tip and testing blocks
General International 12” Benchtop Drill Press (Cost $409)
Husky 120v Air Compressor (Cost $699)
Micro-Adjust Knife Grinding Jig (Cost $255)
Rangermade Knife Grinding Jig (Cost $350)
Two Harbor Freight Vibratory Tumblers w/ Ceramic Media (1 L and 1 S) (Cost $250)
Two 8” benchtop grinders with buffing wheels, scotchbrite wheel, razor sharp system
DC Power Supply for anodizing Titanium (everything you need)
BeBe Carbadizer (Cost $299)
WEN West sharpener with Tormek blade attachments and truing stone
MISC 1-2-3 blocks, Kydex, Kydex Press, Homemade Etching Machine with Chemicals, Epoxy, Ferric Chloride with PVC Container, angle blocks
Asking $12K
- Solid state relay
- blade furniture kit
- Rampmaster III controller
- Thick aluminum quenching plates
- Big roll of heat treat foil
- Heat treat pouches for small blades
- Parks AAA and Parks 50 in Ammo Cans
- tramming kit, professional grade collet set, 20 piece TiN coated end mill set (cost $400)
- 4” precision rotary table (cost $410)
- iGaging DRO set (cost $299)
- Spindle Tachometer (cost $159)
- Blake Coaxial Indicator (cost $399)
- 4” precision vice
- X axis power feed (cost $380)
- 1.5hp variable speed motor
- Tilting flat platen
- Small wheel holder with all small wheels and rack
- Pedestal stand
- Tilting base
- Sharpening Attachment (cost $250)
- 12” Contact wheel on arm (cost $302)
- Surface grinding attachment (cost $1,125)
- Horizontal small wheel work rest (cost $100)
- 12” Horizontal wheel work rest (cost $100)
- 6” Contact wheel on arm (cost $198)
- Slack belt attachment (cost $165)
- 3 Large work rests (cost $375)
- Tons of belts (ceramics, scalloped, scotchbrite, etc…)
- Misting system for post heat treat grinding
- 110v Variable Speed/Reversible 0-3450 RPM 9” Diameter
- Lots of PSA adhesive sanding discs to fit it (ceramic and AO)
- Stabilized wood scales
- Stabilized wood blocks
- Burlap micarts (different colors)
- Layered G10
- Pin stock (G10, brass, etc…)
- AEBL
- MagnaCut
- O1
- 8670
- Nitro V
- S110V
- Titanium pivots, black oxide pivots, etc…
- Titanium 2-56 screws, SS 2-56 screws, black oxide 2-56 screws
- Titanium standoffs, SS standoffs
- Counterbores
- Pocket clips
- Drill bits for common holes
- Caged bearings
- End Mills
- PB washers
- Over $1,000 worth of hardware here
- Lambrich keyless drill chuck ($400)
- Tapmatic 30x tapping head with torque bar ($450)
- 30 gallons
- 175 PSI
- 6.2 CFM @90 PSI
- 2 H.P.
