- Feb 6, 2010
You can get steel flat with a 4x36 bench belt grinder or a flat platen or a 9 inch disc grinder but you had better be able to hold your steel perpendicular to the surfaces or you will have a piece of steel with two flat sides that are not quite parallel. The surface grinding attachment makes quick work of getting steel flat and it will grind tapered tangs in no time. It is worth the money and takes up little space. Larry P.S. Tapping holes is pretty easy but you can get a machinist to drill and tap holes for not much money and have everything perfect. If you are going to make knives for years then you will be glad you set up good equipment to start. LL
