Finished epoxying the handle on a knife a few days ago. Dropped the knife by accident this evening and horrors of horrors the handle slab popped right off the tang!
The tang of the knife was roughened with a diamond grinder, and wiped with acetone just prior to gluing. The ironwood handle had a vulcanized liner glued to it. It was also cleaned with acetone prior to gluing. I used Devcon 30 min. two part epoxy that was perhaps 4 years old. Epoxy was mixed by weight.
The joint failed between the liner and the tang-perfect imprint of the tang in the glue with grinding marks on the tang perfectly replicated in the dried epoxy on the handle.
Could the epoxy be too old? Is there a better glue to use in this application
Any thoughts on what went wrong or how to prevent this in the future. The handle was not pinned yet and perhaps the pins would have prevented the problem but very disconcerting all the same. Makes me worry about other knifes I have done and how they might be holding up in use.
Thanks in advance for any guidance.
John
John
