Eotech XPS2-0 and Bushnell 733960B Trophy Xlt 3-9X40 Matte Doa 600 Riflescope
Feedback: +250 / =0 / -0
Eotech XPS2-0 , NEW in the box. $430 shipped in the USA. Paypal 'gift'. This product is 100% Authentic. (Thats lint in the picture on it, not scratches.)
Shortest model sight yet! This sight is smaller than the former N-cell battery sight (511/551) and runs on a single 123 battery. It also has a longer battery life than the N-cell style sights. Smaller, lighter and always fast with three reticle options. With the new single battery configuration, the XPS allows more rail space than ever, leaving more room for rear iron sights or NV mount.
Single transverse 123 battery to reduce sight length
Shortened base only requires at most 2 3/4 inch of rail space Battery cap and latch are eliminated and replaced with a simple O-ring,tethered cap; better sealing is achieved
Battery compartment is now separated from the base to allow it to hover over the delta ring of the rifle
Average battery life at brightness level 12 is roughly 500-600 hours, 3X battery life of N cell sights
Reticle: 0- 65MOA circle with 1 MOA aiming dot
Available in Night Vision (XPS3) and non- Night Vision (XPS2) versions. The numbers reflect the number of the buttons on the back of the sight.
EOTech Holographic Sight XPS2-0 Specifications:
Optics: Transmission holography - parallax free
Magnification: 1x
Eye Relief: Unlimited
Length/Width/Height: 3.5"x2.4"x2.4" (95.25X60.96x60.96)
Weight: 8oz (227 grams)
Temperature: -40 to 150 F
Waterproof: Submersible to 10 ft depth
Sealing: Fogproof internal optics
Color/Finish: Non reflective black with hard coat finish
Adjustment (per click): 0.5 MOA (1/2" at 100 yds)
Adjustment Range: +/- 40 MOA travel
Mount: 1" Weaver or Picatinny (MIL-STD-1913) rail
Return to Zero: Repeatable to 2 MOA after re-mounting
Night Vision Comatibility: none
Heads-Up-Display Window
Optical Surfaces: Anti-glare coating
Window Dimensions: 1.20" x 0.85" (30 x 23mm)
Front Window Material: 1/8" solid glass
Rear Window Material: Shatter resistant laminate (3/16" thick)
Field of View (100 yds): 30 yds (28m) at a 4" eye relief
Reticle Options: 65 MOA with quadrant ticks and single 1 MOA dot
Electrical
Brightness Adjustment Range: 146,000:1 brightest to lowest
Power Source: (1) 123 lithium battery
Battery Life: 600 continuous hours at nominal setting 12
Brightness Settings: 30 settings with scrolling feature (10 settings for NV use)
Auto Battery Check Indicator: Flashing reticle upon start-up
Auto Shut-down: At 8 hrs- programmable to 4 hrs
BUSHNELL TROPHY XLT 3-9x 40mm Matte Black - DOA 600 Reticle [733960B]
Matte Black
MODEL # 733960B
$130 shipped in the USA. Paypal 'gift'
Features:
•Multi-coated optics
•Amber-Bright™ high contrast lens coating
•One-piece tube
•100% waterproof/fogproof/shockproof construction
•Dry-nitrogen filled
•Flip-Open Lens Covers
•1/4 M.O.A. fingertip, audible / resettable windage and elevation adjustment
•Fast-focus eyepiece
• 91% light transmission
• Butler Creek Flip-Opens lense covers
Specifications:
•Power / Obj Lens 3-9 x 40mm
•Finish Matte
•Length (in / mm) 12.75 / 324
•Reticle DOA 600
•Field of View (ft@100 ft. / m@100 m) 42/14@3x 14/5@9x
•Adj Range in@100yds/ mm@100m 60 / 1.7
•Exit Pupil (mm) 13.3@3x / 4.4@9x
•Eye Relief (in / mm) 3.5
•Click Value in@100 yds / mm@100m .25 /7
