Cbwx34: so you're saying I don't need a burr or there's is a different goal but you still need one? If I have a burr, it should be sharp, right? So there is another problem then. Should I be able to push cut printer paper with the 220 grit? Because it doesn't do that. I raised a burr at 220, should I do the 220 process again to get a better edge?
Thanks,
Bo
Off the 220 the knife should be very sharp.
Once I apex, get a burr on both sides, then I minimize the burr with super light strokes with the 220 and then refine the bevel to whatever the knife calls for.
On subsequent finer grits achieving a burr is not needed and can move progress backwards.
Also I normally use a 220 grit stone for reprofiling and damage.
On a new knife I usually start with 500-1000 grit to take out factory grind lines.
Whatever your first stone is the knife should be very sharp off of it before you go on.
If you are using the EP your problem may be too much pressure.
If you are free hand then most likely it is a consistent angle and pressure.
Good lighting and magnification are key also.
You need to see what you are doing.
Sometimes I will do just one or two passes then inspect the edge many times just to make sure my angle is good.
This is especially important when you sharpen different knives in one setting.
Keep practicing and you will get it.
Then when you do get it hair shaving sharp off your first stone slightly kill the edge on the side of your stone and do it again.
