David Martin
Moderator
- Apr 7, 2008
Thanks Esav . DM
Originally Posted by olpappy
Quote: The results of that testing seems to go against the popularity of high carbide stainless steels over lower carbon choices with regard to edge retention.
"Yes, as there is much hype and little fact in that area."
Quote:
Wouldn't the CPM steels with finer carbides have less of a problem with carbides falling out of the edge?
"No, this is one of the greatest areas of hype. The argument ignores that the steels have so MUCH carbide that the P/M process does not produce finer carbides. The carbides in 12C27M are MUCH finer than those in S30V. Many properties are also based directly on carbide volume, Crucible themselves notes this in their patent articles. They state for example THEMSELVES that since carbide volume is one of the main factors in reducing toughness then using vanadium carbides instead of chromium carbides will increase toughness at a given wear resistance level because less vanadium carbides are needed. Note how Jerry opposes this generalization in the above claiming WITH NO FACTUAL basis at all that you can not predict based on microstructure and specifically carbide volume in spite OF THE MEASURED FACTS with prove otherwise."
Quote:
It sounds like most here can agree that S30V is tougher than other stainless steels but not quite as tough as some of the non-stainless steels.
"The first statement is nonsense propogated by some makers. There are many stainless steels far tougher than S30V."
Quote:
The real big surprise here for me is the question of whether 12C27 or 420HC could be better than S30V in edge retention!?
"Yes, this is MEASURED FACT not subjective opinion."
it is better to do a few well, than to do many poorly.
First of all, who were the "most here" in the questioner's original point?
This is classic Cliff Stamp. He takes the statement "It sounds like most here can agree" and morphs it to "nonsense propogated by some makers".
He did not advance understanding with his grandstanding.
Could some steels be better than S30V in edge retention? Cliff says, "Yes, this is MEASURED FACT ..." but we only have his word for that measurement. Did he use properly heat-treated S30V in the comparison? Ask him and he wouldn't answer.
Me neither.......but he was just one of the major contributors, so there's no need to focus on him.
It was one of those donnybrooks that can yield useful information and be quite funny in some places.
A classic.
Do not repeat his mistakes.
Originally Posted by Nimravus Nut View Post
I do not agree with Cliff about 440a being better in edge holding than 440c ...
"As I said, I never said that, that statement is undefined. I stated 440A has better edge stability than 440C. This will mean it has better edge holding in certain applications, specifically it will hold a high polish at lower angles for longer."
Quote:
The general point I'm trying to make is that S30v is hard to heat treat and it's even harder to get it right to make it tough enough for a large chopper.
"This is a line of hype propagated to respond to the complaints. The reality is that the steel was designed and promoted for EASE of heat treatment and toughness, specifically compared to 440C."
Quote:
Originally Posted by knarfeng
Now if I remember correctly from the micrographs I've seen posted, ATS34 has far bigger carbides than S30V. So if ATS34 is good at 30° inclusive, S30V should be also.
"It depends on the carbide volume as well as CATRA tests generally take blunting to such an extent that they favor wear resistance over edge stability. They are also not well correlated to cutting by people as has been known in Germany for over 50 years."
could this be the reason why S30v is getting so much negative reports...?
"No, the main reason is that it was overhyped far past its actual ability."
you had several guys discussing steel
as we all like to do
