- Feb 17, 2017
Given you push and you cut (sawing motion), there are two things:
A thinner angle will create less resistance (more cutting force / red above). Plus, geometrically, the worn thinner edge will stay thinner (dark blue line), at least for the initial abrasive wear.
I think you're on the correct path here. I don't think it has much to do at all with pressure. As long as you aren't hitting anything hard, the pressure and speed of a cut don't really matter much. It comes down to apex width. Thinner apex = sharper edge. A thinner edge will maintain a thinner apex for longer (right side dark blue line is obviously thinner than the left) resulting in better edge retention from abrasive wear. Talked about at the 10:00 mark in the video below.
