Thanks guys, for the ongoing feedback. Yeah, I'm probably not going to heat up and take off the slabs. I guess I should further qualify this project by saying it will end up a 'personal user' and, even though 'knowing' about the epoxy issue may always bug me as a perfectionist, what I'm shooting for here in the end is a reliable user knife. But looks do matter so...
The other reason I don't want to tear stuff off is that the epoxy issue didn't surface until I had almost completed the handle. There was no 'gap' until I'm assuming I aggravated things by allowing wood and corbys to get too hot during the handle shaping. Only then did the gap start to appear. So I have this perfect handle, ready to be finished, and the gap appears. Ick.
So far, this is the compilation of advice I'm planning to follow (but still open for more suggestions):
1) Match and purchase an acrylic paint to the color of a piece of the liner material.
2) Mix this paint with a small batch of epoxy.
3) Heat the epoxy until its 'runny' enough to be maneuvered into the hairline gap using a toothpick.
4) Carefully sand after allowing to dry.
So... if this 'works' to fill the gap, seal it and look reasonably good, I'll be content. What do you think?
