- Dec 4, 2013
I have started using Blade Bond and it seems to be a pretty good product might be worth you checking out.
I like your idea with the straws. Makes sense. I had to fill some checks (cracks)in the wood on a slab table I made. Just wound up using the slow cure hardener and letting it slowly work its way down and slowly adding more. Took forever. I had syringes, but never thought of straws on the end. I could have gotten into much thinner cracks by squishing the end on a straw.
Okay, So g flex hardener....or is there g flex resin too? Different stuff than 105 resin and 205 or206 hardener? Do people use 105/205/206 for knife handles too?
Justin, I am just figuring I have about 2 litres of West system 105 resin and if that is something that people use for blades I have about $60 worth of it on hand already!
Randy
I will have to head over to the place where I get my West system epoxy from and get some colloidal silica. I see West systems makes that too. I'm sure the shop carries it.
I checked on amazon for the g flex and it is pretty expensive... $50 for the 4 oz bottles of it. Hopefully the colloidal silica is cheaper!
G-Flex is a completely different resin than 105/205/206 and it has it's own hardener. It was designed to glue, among other things, some plastics used to make kayaks. Don't try to mix G-Flex resin with 205/206 hardener - you will probably blow the roof off your shop. Just kidding.
G-Flex is the better epoxy for gluing scales to full tangs because it has a small amount of flexibility. When the tang and scales expand or contract at different rates due to temperature changes, the G-Flex will not break loose.
Tim
