Escalator rattle, help?
Just got a new Escalator, very excited, I love this knife. There is, however a strange rattle that seems to come from the area of the lock. Is this something I can correct or do I need to send it to Rekat?
Robert
Okay, I took it apart. Would seem to be easy to re-assemble, but I can't figure out how the spring fits. Can anyone explain it to me by email?
Rob
Thanks for the lead on that. I will glue the post. Can anyone give me info on how to place the spring in the lock? I didn't get to see it when I opened it, because I opened it and the spring headed for the opposite wall...
Rob
On my Sifu, the spring is glued into place on the end that sits in the handle. I am sure you can do a little superglueing or even a dab of Elmers would keep it from running away, as for the other end, you can do several things. You could hole the spring in place and lay a piece of paper over it and wrap the paper around to the other side of tha hadle and tape it into place till the scale is partially attached to the liner. remove tape, pull out paper from between scale and liner and finish attaching scale. What I did last time was I put spring in place and held it there with my finger and (with the knife on the table) held the scale perpendicular to the knife and moved my finger out of the way as I set the scale on the knife, and then rotated the scale into place, the little bit you have to lift it to get to the lock arm isn't enough to let the spring to fly out.
Gees, I hope that makes sense.
Merry Christmas
YeK
Thanks Dennis and Yekim. After hours of cursing and starts and stops I finally figured out the sequence (no mechanical gunius here) and once again have a great knife, with NO rattle!
Robert
Glad to be of help.
Dennis Bible
Knoxville, Tennessee
