- Feb 20, 2015
A little bit of the appropriate type of epoxy and you'll find those scales will become more suited to your tastes![]()
Yes, like I said permanently fixed then
F1s that have chipped on early use usually don't anymore after the first sharpening. I suspect the edge was probably overheated in production.Bought two F1 models, gave one to my Father. Just really attractive looking knives, with a great distal taper and convex grind.
He used his once to gut a single deer and it chipped way more than any knife should.
After that, I never even used mine. I just admire it once in a while.
My ESEE knives all perform as expected.
I have experienced this with my 3 F1s as well.
They are from 2012-2016. VG10 and 3G.How old are the knives?
All the reports on chipping I've seen has been from pretty old batches.
The L.t wright gns or genesis in sabre might just be for youI am looking for the exact same "do all" light backpacking knife. My first fixed blade. Something that can handle fire prep (harvesting/processing firestarting size material - twigs, vines, featherstick), along with general duty and food prep. Prefer kydex (with a fire steel holder but not required). 3-4" blade, sabre grind, good size protective choil, and a larger handle for my big paws.
The Ursus cub is first on my list, but I am also thinking of the M1 Backpacker, though it may be too small for fire use.
Congratulations! Good choiceThanks everyone for the help, orders placed for an ESEE 3!
Late to see this,but the Italy made version has thinner tip for better detailed work..![]()
3V Master Hunter. Better steel, bigger handle. A little smart shopping and you can pick one up for $120.
OP already bought an ESEE 3, I was just checking up to see how he likes it.I’ve heard that the fallkniven handles are on the small side, so definitely handle one personally before you buy if possible.
The ESEE 4 will have a relatively thick blade. You already have a thick blade in the ESEE 6, so I’d look for a different knife with a shorter and thinner blade ( better slicing capability). Just my opinion, good luck!
I have heard terrible things about Fallknivens warranty and no one’s is better than EseesIs Fallkniven's warranty as good as ESEE's? VG10 steel?
Funny enough, I actually changed things up this week and was thinking I need to update this post…OP, any follow up? Have you made the right choice?
