I am wanting to get a large fixed blade multi-purpose knife to carry on my Tac vest when serving felony warrants. I find myself doing this more often, and so far all I have carried with me is my trusty Benchmade folder (aside from my sidearm and med kit).
I am looking at either the Becker KABK7: Becker Combat Utility Knife:
Blade Length: 7" 1095CroVan
Overall Length: 12.75"
Blade Thickness: 0.188"
Blade Coating: Black epoxy powder coat
Grind: High, flat saber grind
Handle Material: Full tang, Grivory
Sheath: Black Nylon w/ kydex insert
Weight: 12.9 oz.
Made in USA
or the ESEE-6:
Overall length: 11.75"
Cutting Edge Length: 5.75"
Blade length (end of handle to tip of blade): 6.5"
Blade Width: 1.56"
Weight (knife only): 11.8 ounces
Sharpened clip point blade style, full flat grind
Maximum thickness: 0.188"
1095 Carbon Steel, 57 Rc.
Removable lined Micarta handle slabs
Rounded Pommel w/ lanyard hole
Full-tang construction
OD molded sheath; Paracord
Made in USA
The BK-7 is larger, at 12.75" vs. 11.75", with a 7" blade instead of the 5.75" cutting edge of the ESEE-6 (the actual blade is longer, but not the cutting edge, which is what was measured).
However, the ESEE comes with micarta linen scales, whereas the Becker will only come with grivory scales. The micarta linen scales for the Becker is an additional $45. Additionally, the ESEE comes with a sheath that is high quality friction locking, with MOLLE backing. The Becker does not. Its sheath is frankly, pretty pathetic.
The pricing on the ESEE is around $130, and the Becker (with micarta scales) is just under that ($123?).
I think its a pretty clear that I should go with the ESEE, as it comes with exactly what I want (MOLLE compatible sheath), but the Becker is a bit bigger with a really nice blade design. I can picture it with the micarta scales, and it should look REALLY good!
First question: all else being equal, which is the better knife?
Second question: how easy/hard is it to find a friction-lock, MOLLE compatible sheath for the Becker KABK-7?
Weight: 12.9 oz.
Made in USA
or the ESEE-6:
Blade Width: 1.56"
Made in USA
