I want to get another Spyderco...I currently have a Native S30V, and have a ParaMilitary on the way. I want one more Spydie to rotate as a work EDC, and it needs to be somewhat robust as I'm a construction electrician. It will see light duty opening/cutting up boxes, stripping rubber insulation on large copper cables, as well as seeing rough duty, working in underground trenches with water and dirt. As I mentioned I have a Para on the way and it seems all the Spydies that I want seem to have the same blade and handle size's. I want the blade between 3"-3.5" long, and the grip at least 4.25"...While I'd prefer G10 scale, I do like the grippy FRN scales that Spyderco uses, so they will work as well. I've been eyeballing the Mini-Manix, but don't know if it would be any better than the ParaMilitary I'm getting. I also like the Caly 3 but I'm not sure if it will be robust enough. Anyways I'm curious as to what knives you hardcore Spyderco fans would recommend, and why it would be better suited for the workload than the Para?
TIA
Dave
TIA
Dave
