This one has been SOLD, thanks
Here is a ET1 or Entry Team 1 Tanto for sale. Hard use heavy duty blade made from 52100 ball bearing steel. It was designed as a primary or back up blade for military or law enforcement use. The thick heavy blade was flat ground in the Tanto style to almost a zero edge so it cuts nicely. The kydex sheath is set up for and includes a large tek-lok for horizontal carry. Here are the specs:
Steel- 52100 X .270
AOL- 9 3/4 inches
Grind- Flat
HT- In house, blade wa quenched, then normalized and quenched again followed by 3 two hour temper cycles
Blade- 4 1/2 inches to front of scales with jimping on spine
Finish- hand sanded then bead blasted and cold blued
Handle- 5 1/4 inches including the skull crusher
Scales- 4 color camo G10 that has been scalloped for a no slip very comfortable grip. Scales are removable for cleaning
Hardware- two 10mm stainless chain bolts
Sheath . 80 black kydex with large tek-lok for either left or right hand horizontal carry
Asking 270.00 shipped in the USA
Paypal, USPS M/O, or Certified check preferred
Questions or comments welcomed
Thanks for looking
Steel- 52100 X .270
AOL- 9 3/4 inches
Grind- Flat
Thanks for looking
