Hey guys, I have been seeing a pattern develop in my blades of 52100 after the etch for the last couple of batches of blades, Ive also been fine-tuning my heat treat more than ever, and have been getting better cutting performance than Ive ever gotten before.
the pattern started when I started using Aldos 52100, I never got it with mcmaster carr's 52100, it started out that I could see it fresh out of the etch, then it would fade out during the subsequent handling during gurad and handle fitting, until you could barely see it if at all. Now it is coming out bolder than ever, and some stays visible after handling and guard.
What on earth does this? it doesnt seem to be a scratch pattern from sanding, and my etchant seems clean, nothing floating on the surface or floaties suspended in the etchant. I dont get it with my 1095 blades which are etched in the same etchant. It looks like fingerprints in the steel. and this last batch, I can see it in the steel when I get to a 600 grit handsanded finish before the etch. and these blades are cutting extremely well, and exhibit really good edge flexes over a brass rod.
Im forgin at low temps, forgin oversize, and using Ed's Heat treat, {as close as I can, Im not as talented as he is with a torch, so i am just using the forge to heat before the quenches}.
What is this and how do I keep those swirls in the finish from fading?
Joe
Joe
