- Nov 8, 2005
I had a particular challenge with the finishing fittings on this knife. So I'm hoping for some insight into a better way to do things.
First I forged, filed, ground, turned, pinned, soldered, sanded and etched the blade and fittings.
Then drilled and filed the stabilized handle block.
I thought about temporarily super glueing the guard and butt to the block so that I could finish flush, then remove, re-etch and epoxy... but the butt has hidden pins, so I don't think I could shear it loose without damage.
So I permanently epoxied everything, finished the block and fitting edges to 600 grit (leaving the other areas pre-etched), then went through the painful process of trying to expose the metal parts of the knife without soaking the wood.
The result is ok, but the faces of the fittings are far more etched than the sides.
Any suggestions?
Any suggestions?
