- Jun 23, 2008
I've got an irritating etching issue (say that fast three times
) When I electrically etch my blades, I get inconsistent results even though I have gotten very specific to do the same things every time. Attached is a photo of the last three I've done. The top two are 01, the bottom is 440C. The 440C, and ATS-34, Ive used all etch outstandingly, beautiful, crisp, dark etch that stays with it. I have had only a fraction of the 01 blades turn out that well. They all etch, but some loose the darkening, some get a little hazy, many, like the middle blade, are crisp lines but "gravely" inside and won't take darkening. I am using the etchant that IMG sent me that is supposed to be for blade steels. At the time, I told them I was only using carbon steel/alloys but it seems to work better on SS???
Here is my basic procedure- clean the blade with acetone/MEK, lay the stencil on with a dampening of moisture to help hold it in place, dampen the pad with etchant, do three cycles of 4 secs of each polarity, wash the blade off, polish the area with wet 2000 grit to crisp the edges. Sometimes the magic works, sometimes it don't...
Any suggestions?
Any suggestions?
