So i etched my very first mark. It's the outline of texas with my initials inside it. I did several practice pieces until i felt confortable doing a freshly ground blade. I used a 9volt battery with aluminum foil "wires" and lemon juice mixed with a little salt. The etch came out ok, not laser precise of course, but it's serviceable. I cleaned up with acetone and alcohol both, then sanded a bit with 1200 grit and then repolished the area. The next morning the area around the etching was covered in a fine dark brown rust. The steel was 1095. Did i not clean it good enough or do i have to use some oil after etching?
