I use a cricut vinyl stencil for my mask. I coated the sides of the blade with nail polish, but some of the side of the blade got etched, so now I do it before I finish the blade grind so I can clean up any over etching.
How did I not think of that until now ? Now I'm in trouble ,I must try thatIt isn't. Depositing oxidized particles is less durable than oxidizing in situ. And AC doesn't change thickness. Doesn't mean that DC will not make it good. One could consider plating if reverse polarity is a choice.
Imagine this. Damascus blade. Etching your sign. Nickel plate. Acid etch the blade. Polish. Nickel plating would look awesome. Gold over nickel even better.,I must try that![]()
Thank you for more Direct info. That's what I want, literal and direct.Craig, search "MRC Model Train Transformer dual 770N" or "HO scale Athearn SDK-789 model train railroad powerpack transformer" on the 'bay. Some model train transformers are crazy expensive (Lionels), but others will be in the $30-40 range shipped. Look for AC connections, usually on the sides of the unit, not on the top.
Lab bench power supplies are also out there, which sometimes have AC outputs. I found an older, used one on the 'bay for $60 shipped. These are fairly big units.
Found this one as well! I think this will work for etching??
"AC/DC Power Supply - 12.6VAC @ 1A, unregulated / DC output of 3,4.5,6,7.5,9,12V" on the bay looks like it should work as well?
