Spenser, the etching effect of FC comes from the small bit of hydrochloric acid in the solution. If the FC doesn't work you can use muriatic acid (commercial hudrochloric acid) diluted with distilled water. (Make it pretty dilute. Try. Remove blade, mix in more acid in small shots until it etches.) You can also just spike your FC and that will work too.
Also, since 154CM and ATS34 are about the same chemically as Damasteel and RWL34, you can probably etch them with warm sulfuric acid (battery acid).
