etchomatic stenciling solution
Is there a good homemade solution/fluid for etching w/an etchomatic if not
what would you recomend i buy.
Thanks,Bryce
I use 1 cup water 1 tsp salt, 1/4 tsp TSP. Really any saline solution will work. you can replace the TSP with 1 drop of soap. Make a little and try it on some test pieces. This worked better than their solution. Wet the pad and dab on a paper towel to remove excess and dont press too hard.
I follow Patrick's solution and it works well for me. I've used it on 440C, O-1, and CPM 154 with Crawford's etcher modified at 12V.
--nathan
Sorry for the dumbass question please elaborate on TSP,thanks:) Not sure what the acronym stands for.
Ace Hardware... in the paint section... used for cleaning/etching painted surfaces prior to re-coating
Mike
Folks thanks for the replies !!
I need to do a test run now as i was gifted the Etcho-matic From a VERY KIND PERSON here on BF.
I,ll be filling my very 1st consignment this month !!!
WOOOOOOOO HOOOOO !!
And THANKS to the person who gave me the Echo-matic and you folks i,ll be able Sign my work.
If you use 1 steel regularly, buy some electrolyte from TUS Tech.
They have specific solutions for specific steels, or families of steels.
Works like a champ, and is cheap.
A bottle just might last forever, unless it goes bad...
