Aldo has told me to normalize his 1084. Though, if he actually states that a given steel is annealed, take him on his word... he won't steer you wrong. Otherwise, NEVER take for granted that mill steel is normalized/annealed.
The mufflepipe set up is a great way to even out heat and even reduce decarb, if done right. First off, make sure you are using thickwalled pipe(automotive muffler pipe is not thick enough).In a coal forge, make sure you keep the pipe suspended and not sitting directly on the coals or you will get cold spots. You also need to cover the top with brick or Kaowool(ceramic blanket) to retain heat further. I would also not advise letting the blade sit in the pipe. Put the blade into the pipe, edge up and pump it back and forth. Keep it moving.
Merry X-Mas!
