I just got my new evenheat oven set up, and began testing its accuracy with an external pyrometer.
I'm just testing at lower temps for now. I've found that the evenheat's temp reading overshoots the target temp by up to 18 degrees when ramping to 550. That is probably OK, as it is a 22.5 inch oven and there will be more variance than with the shorter ovens.
I'm more concerned about the external pyrometer readings, though. I enclosed the k type thermocouple in a stainless tube, and layed the tube on the firebrick I'll be using to hold my blades. During ramp, the external pyrometer lagged by about 30 degrees until the oven reached about 300, then it sped past the oven's pyrometer reading by up to 60 degrees. I assume this is largely due to the fact that the external thermocouple is encased by stainless steel, and the evenheat pyrometer is encased in ceramic. The steel will absorb the radiant heat faster (I assume) than the ceramic.
However, once the oven reached hold temp (550), the external pyrometer dropped back by as much as 50 degrees (~500). The oven fluctuated +- 7 degrees while holding the temp, but the external pyrometer ranged between 493 and 505, which is a big difference. I held the temp for 10 minutes, and temps stayed within these ranges the whole time.
The oven's pyrometer is about 3 inches higher than the external one, and the external is sitting on a soft firebrick, which will be a heat sink, I guess, so I'm not sure if this is cause for concern or not -- perhaps a blade, with only the spine touching the soft firebrick, would more closely match the oven temp?
The differences cause me concern for hitting target temp and soaking. I'm planning on treating O1 at about 1425, halfway between the recommended 1400 to 1450 range. If the discrepancies are the same at those temps, then in attemping to heat to 1425, I would end up hitting 1485 at the high end, but during the soak time it would drop to as low as 1375.
I'm also concerned about tempering temps -- if I try to temper at 400, the high end would hit 460, and the low end 350.
If I wait until even target temp is hit (i.e. don't ramp the blade), then I avoid some of the fluctuation, and this is fine for tempering, but the specs for O1 say to equalize at 1200, and then bring to 1400-1450. They also warn not to bring temp up to quickly for fear of cracking, but I'm not sure how necessary this is with a blade.
Has anyone else had these problems with the evenheat? Or are my testing methods not valid because the external pyrometer's thermocouple is sitting on a firebrick?
